EG Swaps 1992-1995 Civics
ls-vtec swap
Old Jul 18, 2006 | 07:01 AM
XCEED_EM2's Avatar
Default ls-vtec swap
car is a 94 EG. swapped into an ls-v (B18B block w/ B16? head). got motor complete with ecu and harnesses that go to the ecu, but need help with wiring the other wires that would go to the driver-side harness. much help would be appreciated.
Old Jul 24, 2006 | 11:44 PM
darksidepres's Avatar
Default RE: ls-vtec swap
anyone???
Old Jul 25, 2006 | 11:47 PM
killajay's Avatar
well.. first.. you dont know what head you have... second what year is the ls engine.. third if done right you would only need to wire in the Vtech.. so if you could give more details than maybe you could get some help..
Old Jul 26, 2006 | 12:33 AM
Marty's Avatar
What model EG do you have, is it a EX? SI? DX? BTW I hope you atleast put arp rod bolts in the LS cause if you didn't you better look into chipping your ecu and engauging vtec around 4400rpm and shifting around 7000rpm as the bottom end will fall apart on you above that if you run it up there to many times. Your piston speeds at 7000rpm on the LS stroke will be the same as the piston speed of a B18C at 8600ish rpms.
Old Jul 31, 2006 | 12:08 AM
ORIGINAL: Marty
and besides the piston speeds, the bottom end isnt balanced for over 7K, so I second Marty. do at least a little bottom end work, or that thing will come apart on you sooner or later.
new2honda
Aug 21, 2014 05:49 PM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
projektcivicturbz
May 9, 2007 01:36 PM
abra0101
Jul 23, 2006 08:47 PM
