d-series pulley
Old Feb 6, 2005 | 01:57 PM
riceburner700's Avatar
Default d-series pulley
what kind of tool do you need to take the pulley off, and were i can get it, or can someone show me how to get it off with like a picture or a website that has directions.
thanks dustin
Old Feb 6, 2005 | 03:34 PM
burgo990's Avatar
Member
Default RE: d-series pulley
whats rong with a hammer lmao
Old Feb 6, 2005 | 06:33 PM
Kappa22's Avatar
Are you talking about the crank pulley?
Old Feb 6, 2005 | 09:08 PM
yeah the crank pulley because when ever i put pressure on it it cranks the engine over so is there some special way like an IMPACT GUN to get it off.
Old Feb 6, 2005 | 09:51 PM
Kappa22's Avatar
DON'T use an impact wrench. There's a couple ways to do it (one of them involves a special tool), but for the easiest one, all you need is a breaker bar. Put the socket/breaker bar on the crank nut, brace it against the frame or the ground or part of the suspension, and crank the engine for AS LITTLE TIME AS YOU POSSIBLY CAN (basically, just turn the key to start really fast and let it off). This will cause the engine's rotation to turn against the breaker bar and break the bolt loose. Make sure you brace the breaker bar the right way. Immediately after this, set the engine to TDC from the cam gear and check the crank mark. Then you will be able to take off the TB or whatever else you're planning to do.
And if you're afraid the car will start, you can always pull the coil wire to make sure it won't.
Old Feb 6, 2005 | 11:14 PM
hmmm sounds simple i will also replace the belt to while i am there, what about torquing the bolt back on how many footpounds
Old Feb 11, 2005 | 07:19 PM
got my megan racing blue pulley today looks unbolievable for the price damnnnn
Old Feb 11, 2005 | 07:24 PM
Kappa22's Avatar
What year is your car?
Old Feb 11, 2005 | 07:37 PM
i wouldnt recommend that pulley. sorry, i know this is a little late, but replacing the stock pulley will kill your main bearings and main seal.
Old Feb 11, 2005 | 07:39 PM
Kappa22's Avatar
There's a damn good reason the stock one is so forkin' heavy...
