d-series pulley
what kind of tool do you need to take the pulley off, and were i can get it, or can someone show me how to get it off with like a picture or a website that has directions.
thanks dustin
thanks dustin
DON'T use an impact wrench. There's a couple ways to do it (one of them involves a special tool), but for the easiest one, all you need is a breaker bar. Put the socket/breaker bar on the crank nut, brace it against the frame or the ground or part of the suspension, and crank the engine for AS LITTLE TIME AS YOU POSSIBLY CAN (basically, just turn the key to start really fast and let it off). This will cause the engine's rotation to turn against the breaker bar and break the bolt loose. Make sure you brace the breaker bar the right way. Immediately after this, set the engine to TDC from the cam gear and check the crank mark. Then you will be able to take off the TB or whatever else you're planning to do.
And if you're afraid the car will start, you can always pull the coil wire to make sure it won't.
