Fuel leak
Old Sep 30, 2006 | 04:26 PM
xmctech's Avatar
Default Fuel leak
My '91 Si has a fuel leak that on cursory inspection seems to be coming from the tank to fill tube joint. Can anyone tell me if I need to remove the tank to fix this & if so what is involved?
Thanks.
xmctech
Old Sep 30, 2006 | 04:44 PM
fglaustin's Avatar
Default RE: Fuel leak
seems like it would be the rubber hose that is between the tank and the spout that would be leaking.
hard to say.
should be able to replace the hose without removing the tank.
Old Sep 30, 2006 | 04:58 PM
AgentofDarkness's Avatar
Dropping the tank isn't too difficult. Remove the back seat. Disconnect all the connectors and hoses. Jack the car up. Go under the fuel tank, there will be 2 straps with bolts. Take out the bolts and the strap and the tank should fall out. Remember to put a jack or something under the tank so you can ease it down.
Old Oct 1, 2006 | 07:53 AM
xmctech's Avatar
Thanks guys
xmctech
Old Oct 8, 2006 | 06:53 AM
xmctech's Avatar
It was indeed the rubber hose connecting the tank to the filler neck, specifically a loose hose clamp. I love simple fixes.
xmctech
Dwack1992
Apr 8, 2013 04:05 PM
theRDRman
Nov 28, 2011 04:18 PM
scottylack
Jun 15, 2010 07:29 AM
Kinsrow
Feb 16, 2008 07:31 PM
mokijo2
Dec 27, 2007 12:11 AM
