The build phase 1
Old Oct 18, 2006 | 11:14 PM
Remmy's Avatar
Default The build phase 1
Ok guys. After pulling the Si out of the shop I noticed a small tapping nois I had from the past has grown VERY loud. Almost as if a hammer is smaking on the top of my block. .
It is either:
A: Bad wrist pins
B: Rod bearings
C: Valve (But deemed not the case)
That means the Si is goiing into surgery early. Like... next week early. I will try to document as much as I can.
So! I was going to do some bottom end work like a SRP piston/eagle rod setup. But thanks to Marty, he found something better! Check it:
A fully pre-built bottom end from Import Builders.
B16A block
Wiseco Turbo Pistons, coated skirts
IB Spec H beam Rods
Balanced & Polished Crank
All Honda Bearings
2x blueprinted
New rear main seal
New Type-R oil Pump
New Type-R water Pump
Diamond Bore and Hone
Block guard
= one nasty Si with over 300whp potential DAILY.
Old Oct 18, 2006 | 11:41 PM
amg6975's Avatar
Default RE: The build phase 1
F'ing do it!
New Type-R oil Pump
^ VERY good thing to have.
Old Oct 19, 2006 | 12:08 AM
mxs's Avatar
mxs
word.
Old Oct 19, 2006 | 07:23 AM
You really can't go wrong with that setup man, rock out with **** out
Old Oct 19, 2006 | 08:11 AM
Remmy's Avatar
[sm=drooldude.gif]
Old Oct 19, 2006 | 08:38 AM
Kedawei's Avatar
****'s gonna pull hard as hell. Glad you listened to Marty.
Old Oct 19, 2006 | 08:57 AM
ryank327's Avatar
How much did the bottom end run you? Im looking at building up my 99 si next summer. You can PM me it if you would prefer. That car is gonna be nasty when finished, cant wait to see it!
Old Oct 19, 2006 | 09:06 AM
Remmy's Avatar
It is 2300 shipped. Not a bad price after i looked around.
Old Oct 19, 2006 | 10:20 AM
M.I.N.T.
Old Oct 19, 2006 | 10:47 AM
StifflersMom's Avatar
Cat Fuсker
You bastard:-D That block I would drink vodka out of!
