88 tranny in a 91
Old Feb 15, 2005 | 10:52 AM
hondabboy's Avatar
Default 88 tranny in a 91
hey sup im about to do a 5 spd tranny swap in my 91 civic but the problem is its a 88 tranny. alot of people told me that the 88 tranny will fit but i well need the 88 clutch and keep the same 4spd axles from the 91 because the hubs. is there anything im missing from this swap?? do need the flywheel or anything??[sm=helpout.gif]
Old Feb 18, 2005 | 08:33 AM
PhilStubbs's Avatar
Default RE: 88 tranny in a 91
as long as you use the 88 clutch plate you will be fine. the number of splines is different from the 91 and you can use whatever flywheel and pressure plate you want. im not sure abuot the axles, but i am almost certain that you can use either axles
sway2003
Apr 22, 2008 12:15 PM
Civic Dx 349
Nov 7, 2007 06:35 PM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
