Auto tranny engine to manual tranny: flywheel?
Old Sep 28, 2007 | 08:31 AM
davster's Avatar
Default Auto tranny engine to manual tranny: flywheel?
I am having trouble w/ an '89 D15B2 used engine flywheel issue: I think engine was an auto tranny engine; my 1.5 flywheel, when bolted up to the crank, causes the engine to turn over very hard. Is there another flywheel that I need to use, or does anyone know if maybe the factory auto tranny engine is not compatible with a man. tranny flywheel? (This engine uses a large, heavy, multiple-belt crank/damper pulley, which does not fit on the dead '91 D15B2, single-belt engine).
Old Sep 28, 2007 | 10:23 AM
davster's Avatar
Default RE: Auto tranny engine to manual tranny: flywheel?
The flywheel was binding on the rear main seal that I hadn't recessed far enough into its bore. - Live and learn, I guess.
WellFedHobo
Nov 28, 2008 09:53 PM
BillyB98
Sep 18, 2007 08:52 PM
blown4cylinder
Jul 16, 2007 07:51 PM
97dxcoupe
Apr 15, 2007 07:44 PM
Walshy44
Aug 5, 2006 04:55 AM
