What mod should i put under the hood????
Old May 31, 2004 | 11:01 PM
D16z6's Avatar
Default What mod should i put under the hood????
So far i'm think cold air intake, header, exhaust system, and camshaft.... Anyone got anymore ideas without swapping engine or add nos or turbo???? Plus whats the best brand for it???
Old May 31, 2004 | 11:03 PM
D16z6's Avatar
Default RE: What mod should i put under the hood????
by the way its a 94 Honda Civic EX. Right now it has 125hp and it would be nice getting it up to 200hp.
Old May 31, 2004 | 11:20 PM
NTX's Avatar
NTX
don't forget the fuel system.
Old Jun 1, 2004 | 08:07 AM
polo708's Avatar
underdrive pulleys, lightweight flywheel, hi-flow cat, and an ECU upgrade. The chip will probably cost the most but will make the biggest difference.
Old Jun 3, 2004 | 08:44 PM
lilol89crx's Avatar
p&p head, high comp pistons, aftermarket rods, zex cam, zex valve springs, bisi header, skunk 2 intake mani, adj cam gear, msd 6al, external coil conversion for use with 6al, adj fuel press reg, 310cc injectors, teg tb, lightened flywheel, clutchmasters clutch, kazz lsd, underdrive pulleys. too many to list, what exactly are you going after?
Old Jun 4, 2004 | 12:41 AM
polo708's Avatar
hahaha.... and you thought you were almost done with your car.[sm=smiley2.gif]
Have fun!
Old Jun 4, 2004 | 01:13 AM
NTX's Avatar
NTX
ORIGINAL: polo708
Have fun!
Once you start, you're never done!
eman7131
Jul 27, 2012 04:30 AM
JLguy
Jan 20, 2007 01:14 PM
