Skunk2 Shift Knob
Old Nov 20, 2006 | 05:57 PM
TheMoogly's Avatar
Default Skunk2 Shift ****
Vehicle: 2004 Civic LX (But for any Civic w/a threaded shifter)
Product: Skunk2 Shifter ****
Vendor: Skunk2 (Purchased at local shop)
Cost: $40
Rating: 10 of 10
Install Time: Just about 45 seconds
To install: It comes with a small nut that you screw on before the shifter... then you twist the shifter until it is as low as possible while being aligned right... then you take a wrench and turn the screw until it fastens itself to the **** and holds it secure and you're done! Should take no longer than 1 minute
I am thinking of painting the red in the shifter to silver so it will match the same as the majority of the interior of the car... I will put paint on a tooth pick and fill it as i go... IT IS VERY HEAVY and they told me it will break an aftermarket shifter unless it is solid aluminum... it helps my shifting be a little more smooth and quiet, the shifter weighs probably 2 pounds!
Old Nov 20, 2006 | 10:37 PM
drbyers's Avatar
Default RE: Skunk2 Shift ****
i gots mine...
Old Nov 21, 2006 | 04:34 PM
TheMoogly's Avatar
Tell me how you have your shift boot look so rigid? Mine sags down a little bit and collects dust. Do you have an aftermarket boot?
Old Dec 30, 2006 | 05:07 PM
johnny's Avatar
"Mine sags down a little bit and collects dust": hahahhaahhaha
Old Dec 30, 2006 | 06:57 PM
mybrokenblinker's Avatar
put a zip tie on the lever below the boot. It holds i tup without being visible
works great on mine
Old Dec 31, 2006 | 02:41 PM
TheMoogly's Avatar
YES! I am so stupid, I didnt even think of zip ties! Thanks! It looks really good now!
theRDRman
Jan 2, 2012 08:37 PM
jabomba
May 22, 2008 11:22 AM
drbyers
Aug 30, 2006 12:02 AM
grnrivergirl
Sep 1, 2005 09:12 PM
GotRice?99ex
Jun 8, 2005 07:18 PM
