whats the point?
Old Nov 29, 2006 | 09:54 PM
impreCiV's Avatar
Default whats the point?
ok ive got a few questions, first whats the difference in performance between having a big turbo over a small turbo, like i know the bigger u go the more lag u have but why go bigger turbo? and also whats ctr or itr?
Old Nov 29, 2006 | 09:55 PM
impreCiV's Avatar
Default RE: whats the point?
ok figured it out, civic type R and integra type r
Old Nov 29, 2006 | 11:29 PM
riceburner700's Avatar
bigger can push more hp top end than a smaller turbo...
Old Nov 29, 2006 | 11:31 PM
SovXietday's Avatar
Think of a turbo as an air pump, the larger the pump the more air can be moved. The more air entering your engine the more horsepower you can make. Also, larger turbo's take less heat and less energy to compress the same amount of air than a smaller turbo, less heat = denser air = more power. Smaller turbo's also choke up and restrict exhaust flow easier than large ones, limiting horsepower by not letting the used air out of the engine.
Old Nov 30, 2006 | 03:03 PM
MY99SI's Avatar
in my opinion i would start off with a larger t-3/to4e so that way over time you have room if you ever want to up the boost when you have the mods to enable yourself to go faster
Kleanride
Jun 14, 2007 04:00 PM
knfdeals
Feb 20, 2007 01:19 PM
knfdeals
Feb 19, 2007 07:44 PM
mill$civic
Feb 25, 2006 09:51 AM
dj_ipirate
Oct 30, 2005 06:23 PM
