Boost D17a2
Old Nov 30, 2006 | 12:51 AM
jboib82's Avatar
Default Boost D17a2
I'm thinking more and more about turbocharging my '03 civic ex (d17a2 vtech). But I'm pretty sure i won't be able to run it above 6 or 7 psi, if that. what do i need to do to my engine to properly run a small turbo?
Old Nov 30, 2006 | 09:27 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default RE: Boost D17a2
tune the turbo set up after it in. if you dont tune you can say good bye to the motor in no time. dont push 8 psi on stock internals either.
Old Nov 30, 2006 | 09:29 AM
Do some research into the fuel system aspects of the D17, it's a returnless fuel system, which can play hell with boost
Old Nov 30, 2006 | 10:12 AM
Kedawei's Avatar
ORIGINAL: aryiman98civic
Would you stop perpetuating that misnomer about turbo systems? I see posts all the time from noobs saying "I've heard not to boost over 8psi, is this true?" generalizing the statement to any motor and any turbo and any engine management/tune. 6 months ago (or w/e) when you were still first learning about turbos, it'd be ok. But I know you know better by now.
Old Nov 30, 2006 | 10:21 AM
Belmont's Avatar
8 psi is safe/reasonable boost for stock (internal wise) civic engines. I wouldnt boost past 6 psi on stock internals with a d17.
Old Nov 30, 2006 | 10:47 AM
Pete's Avatar
I wouldnt boost it.
Old Nov 30, 2006 | 10:52 AM
My04Civic's Avatar
Administrator
<-----D17A2 with I/H/E and i cant complain
Old Nov 30, 2006 | 11:27 AM
SovXietday's Avatar
Does anyone even know if it's possible to tune these things without buying a standalone?
Old Nov 30, 2006 | 11:39 AM
Belmont's Avatar
ORIGINAL: Pete
I wouldnt boost it.
The d17 can put out decent numbers. Its not cheap but they can handle up to 300 hp.
Old Nov 30, 2006 | 05:15 PM
jboib82's Avatar
Basically, in the end i want to be able to push about 210-220 horsepower while maintaining the car's reliability. Any other ideas?
wbogle
May 9, 2006 09:05 PM
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
baker
Nov 8, 2005 02:42 PM
Thorium
Jul 15, 2005 10:54 AM
