Mid West IL, IN, IA, MI, MN, MO, OH, WI
Anybody in NW Indiana?
Old Dec 18, 2006 | 05:48 PM
burnindesirez02's Avatar
Default Anybody in NW Indiana?
Anybody for NW Indiana who knows how to change Outer tie rod ends?
Old Dec 20, 2006 | 04:44 PM
AgentofDarkness's Avatar
Default RE: Anybody in NW Indiana?
I know how to change outer tie rod ends. I'm just outside Chicago. Its actually not to difficult. Jack car up, wheels off. Remove castle nut on top of tie rod end. Use a suitable pickle fork to seperate the tie rod and the control arm. Screw off old tie rod. Screw on new tie rod. Put new tie rod on top of bolt. Install castle nut. Install cotter pin. Put wheels on. Take the car to the alignment shop. I'll go look at my manual later on and make sure this procedure is correct. I wrote that up off the top of my head.
Old Dec 21, 2006 | 02:47 PM
I wouldn't mind doing my tie rod ends its just that i have no tools for this job at all. i only have a set of sockets and a cresent wrench.
Old Dec 22, 2006 | 11:49 AM
Go to autozone and rent a tie rod seperator (you have to put a deposit on it). You should only need a 10mm (for a 95 civic) and all the stuff required to remove the tires and jack the car up.
Old Dec 22, 2006 | 08:55 PM
you dont even need a tie rod separator. I was helping my cousin with it and to get the control arm separated from the tie rod he hit it a couple times and it came right off. It was alot easier than it looks
bigfrank
Mid West
66
Aug 3, 2011 09:24 AM
buttascotch_3
Feb 4, 2006 05:49 PM
trickyvick
Dec 8, 2005 08:44 PM
KnightRiderCivic
Mid West
Aug 14, 2005 11:52 AM
j_fukin_t
Aug 9, 2005 03:42 PM
