CV joint
Old Jan 13, 2007 | 09:27 AM
tallgood's Avatar
Default CV joint
Can anyone tell me how hard it is to do aCV joint replacment or complete drive axle? I suspect our 97 coupe with 1500000 miles on it is in need of at least one side or the other. Starting to get some noise while turning to the right.
Do it youself project.
Or better to have a shop do it.
Old Jan 13, 2007 | 09:52 AM
ryank327's Avatar
Default RE: CV joint
Its not tough to do it yourself.
Heres a couple DIYs to give you an idea of what you would have to do
http://honda-tech.com/zerothread?id=1135275
http://honda-tech.com/zerothread?id=382416 (has no pics and is for b-series but it will give you a good idea)
You best bet is to just get a rebuilt axle assembly which will run you about $100
Old Jan 13, 2007 | 04:05 PM
7th generation civic's Avatar
My inner cv joint mash up(right side) last month, the whole inner housing case was cracked. I had to replace the whole axle, I bought it used, cost about US$200, brand new in company isUS$650. My mechanic did the work ,and the car is running ok now.
by the way the car is the 2001 civic ES1
Old Jan 14, 2007 | 08:40 AM
tallgood's Avatar
Thanks for the info.
Old Jan 14, 2007 | 01:44 PM
Kedawei's Avatar
1.5 million miles ftw. [&:]
evictor99
Dec 5, 2009 01:00 PM
Unc0ntr0l
Apr 17, 2006 03:26 PM
Impreza WRX
Jan 27, 2006 03:05 PM
stuartm27
Jul 7, 2005 02:25 PM
