NAVIGATION PROBLEM
hey guys, i have a question. i just bought the Honda Civic SI and i lovee it. i got it with the navigation but i would like to somehow get it to workwhile driving. does anyone know the best wayi can do that?
i assume you mean it works only when the e-brake is on.. in which case all you need to do is bypass the wire that goes to the e brake... im not entirely sure how to do it. but that should be the only thing you need to do. on older model cars.. the e-brake is usually pretty loose and the wire trips even if you pull it up just one click.. soyou could pull it up just 1 click and that should bypass the e-brake wire. but i think they were more careful with that on the newer model cars. so i dont really know. take a look at the e-brake and the wire thats attatched and figure out how it works. then you should be able to fix your problem. if not. post again and we'll try to figure it out.
ahcollin
Nov 23, 2010 07:19 AM
