worth boosting this engine
Old Feb 22, 2007 | 10:10 PM
ic892003's Avatar
Default worth boosting this engine
do u guys think it would be worth boosting a d15b7 engine and safeat maybe 6-7 psi with a Good tune?? or just a waste of time and $$?
Old Feb 23, 2007 | 06:41 AM
cbaber's Avatar
Default RE: worth boosting this engine
Do a Mini-Me, then turbo it. Putting a VTEC head on the motor alone will give you a big noticable power gain and would be about the same as a z6 or y8.
Old Feb 23, 2007 | 07:21 AM
ORIGINAL: cbaber
Mini-Me ftw. You should do mini-me alone and see hwo you like it, i that think bolts on like 26 hp or something. Then boost it from there
and yes, i do think it would be worth it. D-Seires enginse respond well to boost (or so i've heard)
Old Feb 23, 2007 | 08:18 AM
ic892003's Avatar
but doesnt a mini-me give u high compression, therefore isnt it bad for boost?
Old Feb 23, 2007 | 09:20 AM
true....i'll give ya that. I know riceburner swapped his engine for a non-VTEC one and then boosted it because he said "he doesnt want to deal with VTEC, its just another thing that could go wrong"
so either way i guess, VTEC will definately add some more power, and its not like boosting a VTEC is bad, i mean people all over the forum here have it. Either way, boost will be awesome. How many miles for your engine have? Get a compression/leak down test and if all is well, youre good to go
Old Feb 23, 2007 | 11:01 AM
ic892003's Avatar
engine has 116k on it
Old Feb 23, 2007 | 11:20 AM
get a compression/leak down test and if the engine is in legit running coniditon you should be good man
Old Feb 24, 2007 | 10:45 PM
Marty's Avatar
ORIGINAL: ic892003
more times than not no it does not, depends on head selection but a Z6/Y8 head tends to not jump compression more than a .1 or .2 points which really dont mean anything.
Old Feb 25, 2007 | 12:32 PM
https://www.hondacivicforum.com/m_217217/tm.htm
don't worry about the compression
Old Feb 25, 2007 | 05:06 PM
ic892003's Avatar
yea i think im gunna get a z6 head and then boost it, my only worry is getting my mechanic to put he head in properly, is it hard to wirre up the vtec when doing the mini me swap and also what gains can i expect from the vte4c z6 head on a d15b7 block?
extreme
26
Mar 6, 2008 02:18 AM
deadphishy
Feb 26, 2006 05:09 PM
carboncivic
Nov 30, 2005 12:22 AM
schweigel
Oct 17, 2005 10:33 PM
rzimmer11
Mar 19, 2005 11:18 PM
