hf or dx?
Old Mar 2, 2007 | 10:57 PM
skateman190's Avatar
Default hf or dx?
is there a way to tell if i have a hf or dx hatch? i got the car for free and neither the title nor the car says anywhere on it what it is. thanx, allen
Old Mar 3, 2007 | 01:32 PM
Powermidget's Avatar
Default RE: hf or dx?
hf has 4 wheel drum brakes i believe so if you have disc front brakes then its a dx...i could be wrong so dont hold me to it...i think the hf is an8 valve 1.5...the dx is a 16 valve 1.5
Old Mar 3, 2007 | 03:19 PM
well ill have to take off the steelies to find that one out, lol. also i have a d15b1(supposedly 8 valve according to the specs, but my valve cover says 16 for some reason) i was hoping there might be a way of telling by the vin# or sumthin
Old Mar 3, 2007 | 03:27 PM
looks like a dx from what im gettin from the vin code, thanx guys
Old Mar 8, 2007 | 11:03 PM
finalimpact's Avatar
d15b1 comes standard in the civic std/cx. there is no hf model for hatchbacks. easiest way to id if you have a std/cx model is you will have only low and high wiper speed options, a 4spd transmission, no rear wiper, vynil seats, no tach, no clock, and no center console around your shifter. this is of course your car is bone stock. a dx will have the d15b2 and will have intermitent wiper speeds, rear wiper, 5spd tranny, clock, center console around the shifter, tach. i personally like the std/cx model since its the lightest available for the hatchs. and suprisingly the std/cx is lighter than the crx dx and si. the only downside imo is that the std/cx model uses the smaller spline axles found also in the crx hf.
Old Apr 5, 2007 | 04:35 PM
markwilson's Avatar
AS for knowing if its 8 or 16 valves why dont you just take the valve cover off, shouldnt be hard.
