b18a1 in a 1990 Honda civic dx hatch
Old Mar 8, 2007 | 07:05 PM
alteredimages's Avatar
Default b18a1 in a 1990 Honda civic dx hatch
I put the motor into my car and stuff and i did the wiring to change from the dpfi to the mpfi according to what i have seen on this site. The car turns over but it is not getting any gas to start. i pulled off the fuel liine that goes to the fuel pressure regulator and no gas flows through also my dash light don't come on for some reason just the engine light can anyone help me out with this one i am so close to getting the car running.
Old Mar 13, 2007 | 09:19 PM
htowncruiser's Avatar
Default RE: b18a1 in a 1990 Honda civic dx hatch
have u double check ur wiring and for the gas it maybe the fuel pump does it turn on when u turn thekey switch is on.
Old Mar 14, 2007 | 12:36 AM
yeah the fuel pump makes noise and the wiring seems to be right i checked it more than a couple times. Now what im trying to do is to use my old dpfi harness and wire in the injectors and stuff and imma see if that works.
Old Mar 14, 2007 | 01:30 AM
finalimpact's Avatar
did you hook up the ecu grounds at the thermostat housing?
Old Mar 18, 2007 | 07:03 PM
okay so i said screw it and i took of the ls wiring harness of the motor and i put the dx wiring harness in then i ran all the wires and stuff. The car finally starts. Now it runs like **** though when you give it gas it doesn;t do anything unless you hold it for a while then itll start to rev up slowly. Anyone have any ideas.
pilcher311
Sep 26, 2011 01:11 PM
RowensSpecV
Jul 15, 2007 08:29 PM
bikerboycain
May 16, 2005 10:54 PM
pkfrdh
Mar 18, 2005 04:11 PM
