What's wrong with my oil/engine?
Old Mar 14, 2007 | 12:29 PM
10isAce's Avatar
Default What's wrong with my oil/engine?
I installed an oil catch tank b/c the breather I put on the valve cover would allow oil to blow all over the firewall. So after 3 weeks of having the catch can I need to drain it b/c it was getting full and this is what was in there.
I'm assuming b/c the breather was shooting out oil there is a problem with the rings, or something internal. I'm only running 6-7psi on boost for the last 2 years with 140K miles on the engine. Time to rebuild?
[IMG]local://upfiles/4625/769F8D91C7374EFB8FAAB63D61CB14CA.jpg[/IMG]
[IMG]local://upfiles/4625/9796E5702C4D4D70A1B0D4584EBA431D.jpg[/IMG]
Old Mar 14, 2007 | 12:33 PM
10isAce's Avatar
Default RE: What's wrong with my oil/engine?
By the way I'm using Mobil 1 Synthetic 5-30w
Old Mar 14, 2007 | 03:51 PM
Kedawei's Avatar
I would guess coolant in the oil. Blown headgasket maybe? Do a compression/leakdown test.
Old Mar 14, 2007 | 06:11 PM
easy101's Avatar
ORIGINAL: Kedawei
those were my first thoughts as well.
Old Mar 14, 2007 | 11:39 PM
riceburner700's Avatar
i have never seen oil look like that even with coolent in it. usualy coolant and oil is like a milky tan color...
Old Mar 15, 2007 | 12:40 PM
easy101's Avatar
ORIGINAL: riceburner700
the pictures look close enough to me...what else do you think would be causing his oil to look like that?
Old Mar 15, 2007 | 12:45 PM
do you have any like oil additives in the engine oil?
Old Mar 15, 2007 | 01:21 PM
Kedawei's Avatar
I'd say that is pretty milky and tan.
Old Mar 15, 2007 | 01:29 PM
SovXietday's Avatar
From what I understand that is normal to have some sort of gunky yellowish **** in the catchcan. I don't know what it is or why it's there but from what I've heard it's common.
Do a leakdown/compression just to make sure though.
Old Mar 15, 2007 | 01:39 PM
mxs's Avatar
mxs
I've seen this before, general consensus seems to be that it gets "frothy" and oxygenated which changes the color. Oil in your engine still looks fine, right? don't worry about it.
Capnx
Jan 10, 2015 04:24 PM
oilltd
Jun 10, 2008 04:06 PM
dave_57204
Nov 15, 2007 09:24 PM
FlipHKD720
Apr 27, 2007 04:35 PM
