5w-20??
Old Mar 30, 2007 | 12:30 AM
Wifes Civic's Avatar
Default 5w-20??
My wife just bought a new 07 Civic. The manual says use 5w-20 oil, and does not list any oil change intervals, just follow what the oil life moniter says. Si oil spec is 5w-30.
What do you guys think? Any problem with warranty if I switch to 5w-30. I don't care about whatever bit of gas mileage increase there might be. I would rather protect the engine, she keeps her car forever. I always domost of my own maintenance, including oil changes, how will that affect any future warranty issues? What about Amsoil and Mobil 1 with extended oil drain intervals and the Honda warranty?
New to this forum, if there is a place where this has already been beat to death, just point me in that direction. I don't care to get into any debate over oil, just the effect on engine and warranty.
Old Mar 30, 2007 | 12:57 AM
blackmetal619's Avatar
Default RE: 5w-20??
no it wont void the warranty. depending where you live, most people use 5w30, or 10w30
Old Mar 30, 2007 | 03:18 PM
Kedawei's Avatar
Default RE: 5w-20??
Use what it says to use for that vehicle, or contact a dealer/manuf. if you have any questions. Most civics use 30 weight, but apparently not all. These oils are quite different.
Old Mar 30, 2007 | 03:20 PM
drbyers's Avatar
Default RE: 5w-20??
use 5-20. the newer engines have tighter engine tolerances.
it costs the same as 5-30 so it won't hurt your pocketbook any and you'll be following manufacturers maintenance requirements should something go wrong with your engine.
Old Apr 2, 2007 | 09:30 AM
cderalow's Avatar
Default RE: 5w-20??
ORIGINAL: Kedawei
the hybrids actually use 0W-20
Old Apr 2, 2007 | 10:23 PM
riceburner700's Avatar
Default RE: 5w-20??
just change it every 3000 miles or if you are using synthetic go every 5000
Old Apr 3, 2007 | 03:01 PM
Kedawei's Avatar
Default RE: 5w-20??
ORIGINAL: riceburner700
I don't agree with that. Get your oil tested. VI won't start to shear on non-synthetic even at 10k miles. I used tochange mine at 5k because of crap filters, and because of the way I drive. If it weren't for that though I would have taken them to 10k without worries. I'm on synthetic now changing at 7500 because of crap filters. I haven't tested it (Mobile 1 5W-30) to see how it does, as I only recently made the switch. I intend to though.
Fleet cars change their plain old non-synthetic every 15k-30k miles.
