75mm Vitaras question
Old Apr 19, 2007 | 01:34 PM
Fiasco's Avatar
Default 75mm Vitaras question
Im having a hard time on turbod16.com figuring out if the block needs any honing with the 75mm Vitaras? If im reading the threads right, it seems a 75.5 oversize does but the 75 drops right in? Can someone tell me what machining will be neccessary if not?
thanks!
Old Apr 19, 2007 | 03:01 PM
Kedawei's Avatar
Default RE: 75mm Vitaras question
75 will drop in but they will fit loose. By Honda's standards they would be out of tolerance. That is why I will not use them. There is a buy going on, on d-series.org right now for 75.5mm is the seller gets enough interest.
Old Apr 24, 2007 | 08:19 PM
t34me's Avatar
I run the 75mm, do not have one problem. Slightly louder than normal at start up, once it gets warm you dont know the difference.
Old Apr 24, 2007 | 09:00 PM
Kedawei's Avatar
Most people who use them will say that. I'm just a tolerance/torque ****. Trained to be that way.
Old Apr 24, 2007 | 09:25 PM
t34me's Avatar
understandable, if there had not been all the proof that they work great in D's, i would have said screw it. Trust me, everything else in that motor is 100% by the book as far as torque and clearance #'s are concerned.
Old Apr 25, 2007 | 01:50 AM
Lost's Avatar
ORIGINAL: t34me
what do they sound like?
Old Apr 25, 2007 | 10:38 AM
the_turtle's Avatar
just a little bit louder tone i think he means....
so you run the 75mm....im going to be building up my D so i guess ill have to look at some prices for them.
Old Apr 25, 2007 | 11:34 AM
t34me's Avatar
ORIGINAL: Lost
ORIGINAL: t34me
Its like a soft clicking.Closest thing i guess it sounds like you need a valve adjustment, but like i said, as soon as it warms up, it goes away.
Old Apr 25, 2007 | 11:59 AM
the_turtle's Avatar
holy crap....thats what i figured it was....only cuz i know the sound....buti didnt really feel like explaining it!!!! thats crazy. lol
Old Apr 25, 2007 | 03:49 PM
Kedawei's Avatar
That is called piston slap. The sound is the piston slapping the cylinder wall a bit until it warms up and expands. It is obviously not major or people would be having problems immediately.Just let the engine warm up before you drive it.
