Overheating.. tell me if im right
Old May 2, 2007 | 08:08 PM
StevieG1223's Avatar
Default Overheating.. tell me if im right
Ok I bought a 93 civic ex about 10 days ago. When I was leaving the dealership the guy forgot to put my radiator cap on. Needless to say the car overheated so I went to the local auto store and picked up another cap the guy said would work. It worked for maybe 3 days. Now my car has coolant sputtering out of the rad cap and the overflow has boiling coolant in it. If I go to my local auto zone and get another cap that threads on properly what are the chances my problem will be fixed?
Thanks,
Stephen
Old May 2, 2007 | 08:10 PM
Mr Mobsta Man's Avatar
Default RE: Overheating.. tell me if im right
You should just go back to the place u bought it and have them fix it if it was their fault.
Old May 2, 2007 | 08:11 PM
1.5 hours away and the car passed inspection for the lemon law.
Old May 2, 2007 | 08:20 PM
Impreza WRX's Avatar
16 PSI 16 PSI!!!!
Old May 2, 2007 | 08:26 PM
it says 16 pounds on it but it doesnt thread on properly. Do you think I will have different results with a oem cap?
Old May 2, 2007 | 08:37 PM
Here's your excuse for a $140 (with shipping) all aluminum eBay radiator, complete with cap. racing_guys is selling them.
Old May 2, 2007 | 08:43 PM
the radiator isnt leaking its sputtering coolant out the top and into the reserve
Old May 3, 2007 | 12:11 AM
elusive_da's Avatar
is ur fan kicking on????
Old May 3, 2007 | 08:47 AM
mlobitz's Avatar
Member
I had a similar issue, it turned out the fan switch was bad and the fan wasn't turning on.
Old May 3, 2007 | 03:37 PM
If you haven't already done this, heres how you test the fan.
Take off the plug hooked to the fan sensor (its on the t-stat housing most likely). Fold a paperclip or wire into a U shape. With the key in the ON position (motor not running), jump the wire by inserting your paperclip into the plug, bridging the two contact points. The fan should kick right on.
farmerjunglejoe
Jul 7, 2014 10:30 AM
jordan101
Dec 3, 2011 01:25 PM
ffjosh
Mar 4, 2011 06:48 AM
trebor_2005
May 19, 2006 01:40 AM
Figgaz
Dec 13, 2004 10:50 PM
