put rims on but problem
Old May 31, 2007 | 08:51 AM
ic892003's Avatar
Default put rims on but problem
y car veers to the left since i put on my rims yestertday, that measn all i need is an alignment now rite?
Old May 31, 2007 | 09:07 AM
rice_patrol's Avatar
Default RE: put rims on but problem
either that or i think you wheels need to be balanced
Old May 31, 2007 | 11:49 AM
ic892003's Avatar
they were balanced be4 the guuy put the rims onym ycar
Old May 31, 2007 | 12:08 PM
Fiirkan's Avatar
AIR PRESSURE!!!.... that is all....
Old May 31, 2007 | 03:38 PM
ic892003's Avatar
i checked the air pressure, its fine
Old May 31, 2007 | 03:40 PM
MY99SI's Avatar
check the camber
Old May 31, 2007 | 04:43 PM
might be just alignment....... but if it all asudden pulls hard then thats odd... cause if it was alignment ya shoulda at least left it alittle with stockers....
ya might want to lift the front end off the ground and then put the car in gear and get out and look at the wheels... if the wobble.... then mounting was probably messed up..........
just remove the wheel and torque the wheels back on properly........ dont just tighten one lug and then go to the next one.... always crisscross snug them and continue torqen the lugs down... and try it again up in the air and see if the wheels wobble any.
if its not that then are the wheels new or used? maybe the wheel is jacked up.....
Old May 31, 2007 | 05:23 PM
ic892003's Avatar
the wheels and tires are brand new, thats wut im saying, but it doesnt pull to strong, but if i let go off the wheel it will veer a little to the left, is this normal with new rims and tires their 16' rims with size 205-45-16 tires, i think its an alignment i just want to make wure this is normal
Old May 31, 2007 | 05:30 PM
well if the tires arent the same outter diameter as the stockers than that could be the problem which will increase the offset on the alignment.....
might wanna check the tire size calculators and see if your speedo is off any now either... and just get a alignment...
DaHonDa
Dec 3, 2012 12:31 PM
txedomask433
12
Jul 15, 2007 01:57 PM
cornerblitz59
Jul 24, 2006 10:51 PM
hisokano1
Apr 3, 2005 08:30 PM
Vovka86
Oct 6, 2004 09:20 PM
