EK Swaps 1996-2000 Civics
b16 swap
Old Apr 27, 2005 | 02:49 PM
ballplaya4eva07's Avatar
Default b16 swap
I have a 97 ex. Which b16 motor swaps directly into my car? Also what are the best sites for buying a complete swap?
Old Apr 27, 2005 | 05:58 PM
jdmekb16's Avatar
Default RE: b16 swap
You can use the SIR-II full change over kit you would just have to buy a OBD-2 to OBD-1 conversion harness which aren't very expensive to run the ecu also you would need a OBD-1 dizzy there would be very little wiring to do. That is probably the cheapest route cause a OBD-2 B16A2 is going to cost a pretty penny since they were only offered for 2 years. If you want to go OBD-2 go with the GSR motor instead there are more aval. so you can find them cheaper plus there
no replacement for displacement. The axles that come with the change over kit are the ones you need. You also don't need a engine mount kit since your car is a 97.
i used www.hmotorsonline.com
thatguywithahonda
Jul 3, 2013 07:36 AM
turbo speeder
Jan 28, 2009 03:57 PM
kobejelbryant8
EG Swaps
Jun 9, 2005 01:05 AM
droolincivic
EG Swaps
Sep 24, 2004 02:15 PM
outlawzz23
Aug 9, 2004 08:21 AM
