2002 honda civic radio into a 1995 civic
Old Aug 25, 2007 | 01:55 AM
mr honda's Avatar
Default 2002 honda civic radio into a 1995 civic
Hello people,
I have a 2002 honda radio/cd player and am trying to install into my 1995 civic, but need to know which wires go where on the 2002 radio. I bought the radios pig tail plug at a wrecking yard and havnt been able to locate any diagram thats shows what each wire is for. Does anyone know where I can find a description or schematic of what each wire is for?
Old Aug 25, 2007 | 07:43 AM
KarTuneMan's Avatar
Default RE: 2002 honda civic radio into a 1995 civic
+12V DC Battery(Constant)
White/red
Pin A10
10 amp
Underhood fuse/relay box
Switched Accessory
Yellow/red
Pin A2
7.5 amp
Underdash fuse/relay box
Ground
Black
Pin A20
Illumination
Red/black
Pin A9
Dimmer
Red
Pin A19
Left Front +
Green/yellow
Pin A7
Left Front -
Gray/red
Pin A17
Right Front +
Green/black
Pin A8
Right Front -
Light green
Pin A18
Left Rear +
Blue/white
Pin A6
Left Rear -
Blue/black
Pin A16
Right Rear +
Pink
Pin A5
Right Rear -
Blue/yellow
Pin A15
White/blue
32
7.5 amp
Fuse box under hood
Switched Accessory
Yellow/red
23
15 amp
Fuse box under dash
Ground
Black
Illumination
Red/black
Left Front +
Blue/green
Left Front -
Gray/black
Right Front +
Red/green
Right Front -
Brown/black
Left Rear +
Blue/yellow
Left Rear -
Gray/white
Right Rear +
Red/yellow
Right Rear -
Brown/white
The TOP is the 2002, the bottom is the 1995.
Old Aug 25, 2007 | 07:44 AM
KarTuneMan's Avatar
I have NO IDEA why they stacked up the way they did. When I copied and pasted the were layed out fine.
Old Aug 25, 2007 | 08:21 AM
mr honda's Avatar
oh if you were in my town I would buy you a drink thanks so much it works. Now do you know how to enter the unlock code?
Old Aug 25, 2007 | 09:24 AM
mr honda's Avatar
ok figured it out, I just wasnt entering it fast enough, it worked..and the radio and cd player works great. I put it on a 12v power supply to test it out of car..........not too bad for a 25 dollar cd radio player from ebay
Old Aug 25, 2007 | 09:31 PM
KarTuneMan's Avatar
Congrats my friend.......
teferi
Jan 19, 2015 05:16 AM
DaHonDa
Dec 3, 2012 12:31 PM
limerence
Nov 17, 2007 10:59 AM
cloudbreakmd
Nov 15, 2006 07:50 PM
