won't start in warm weather
Old Sep 17, 2007 | 12:17 PM
mtgirl's Avatar
Default won't start in warm weather
I've been trying to help a friend get his Honda back in complete working order, but I'm stumped on this one.... it's a '91 civic EX, with about 180K miles.... it works great, when it starts! Anytime the temp outsideis above about 70, it won't start. If he leaves it sitting overnight, giving it at least 4-5 hours to "cool down" it's fine.
SO?! What does this mean (aside from the fact that it's time to upgrade to a new Honda?)
Old Sep 17, 2007 | 12:20 PM
My04Civic's Avatar
Administrator
Default RE: won't start in warm weather
this means its not a honda cuz "car always start!"
syke umm...so is is the weather that needs to cool down or the engine??
Old Sep 17, 2007 | 12:21 PM
xramseyx's Avatar
Main Relay. There have been multiple people with this same problem. all have been which of that the main relay. Located under the driver side kick panel. Big grey fuse, with a brown plug thing. Says "Mitsuba" on it.
Old Sep 17, 2007 | 12:22 PM
My04Civic's Avatar
Administrator
winner
Old Sep 17, 2007 | 12:47 PM
mtgirl's Avatar
you guys are great, i'll check it out!
Old Sep 19, 2007 | 07:01 AM
mtgirl's Avatar
ok, since a certain auto parts store that shall remain nameless, sucks, we got the wrong relay! UGH! I went back in 3 times, and they kept messing me up! Anyway, I decided to go to a different parts store, but it was pretty late at night and everything was closed. We only removed the relay once, and put it back on immediately.....
This morning, the car started (it was only 50 degrees out).. but about 2 miles down the road it died! Apparently when the gas peddle was depressed, nothing happened- car coasted to a stop and then died completely. Now it won't start at all.
This is still a main relay issue, isn't it? Probably the relay is so shot that the fuel pump isn't working now? Is the best thing to do, replace the Relay first, then if the problem still exists, look at the fuel pump itself?
Old Sep 19, 2007 | 07:14 AM
My04Civic's Avatar
Administrator
that sounds like a great idea...def. get the right relay
Old Sep 19, 2007 | 08:03 AM
LarsonSi_0091's Avatar
it could also be the distributor mycar did the same thing until i got a new one. the coil and ignitors are know to go bad. the coil controls the spark and fuel pump also.
Old Sep 20, 2007 | 09:11 AM
mtgirl's Avatar
ok, you all rock! it was totally just the main relay!but, now, new project!
I think we need to replace the dimmer switch? the instrument panel won't light up consistently, and from what i'm gathering the dimmer seems to be the issue? Can you confirm this? and if it is, can you tell me what i need to do to fix/replace it? Thanks!
Old Sep 20, 2007 | 09:18 AM
buy a new dimmer switch it just unplugs then when u get a new one you can just plug that one in.
