troubleshooting!
Old Sep 17, 2007 | 07:01 PM
xramseyx's Avatar
Default troubleshooting!
Ok guys ive searched this a bunch, ive tried it a couple times....
The 2 pin jumper to get the codes. Tried a wire, saftey pin, paperclip... everything.
I cant get my car to spark... My fuel pump doesnt kick on, ive tested 2 Main Relays, even mine in another car. Changed the dizzy out.
Now when i try to get some codes... My CEL just STAYS on.
Also, i took an p28 ecu from a friends car and plugged it in... still the same thing!
TROUBLE! HELP NEEDED!
Thanks guys
Old Sep 17, 2007 | 08:45 PM
LarsonSi_0091's Avatar
Default RE: troubleshooting!
did you try a new dizzy because my car had the same problem and it ended up being the coil in the dizzy.
Old Sep 18, 2007 | 03:23 AM
when you're in diagnostics mode, and the CEL just stays on, that means there are no codes.
Are you getting a CEL when NOT in diagnostics mode?
Old Sep 18, 2007 | 05:55 AM
xramseyx's Avatar
Yes, i changed my i/h/e... then my CEL came on. I figured it was cuz the exhaust and what not. I didnt think anything of it... Now, does that mean that its code 0. ECU right? We switched ecu right after that... same thing.
Ive tried a new coil.. got my ignition control module checked out... nothing.
Old Sep 18, 2007 | 06:47 AM
info on the car/motor/mods?
Old Sep 18, 2007 | 07:03 AM
xramseyx's Avatar
95 civic ex coupe 1.6 z6
Power everything.
Lowered
Homemade 3' intake.... Ebay special Header, with a N1 style hi-flow cat. Thermal cat back.
New starter...
12' JL Audio sub and 300 Watt amp.
Nothing else i can think of about it.
schainm
May 9, 2007 09:51 AM
redlines4us
Sep 14, 2006 11:32 AM
schan00
Jun 2, 2006 04:20 PM
rallystang
May 7, 2006 08:44 PM
althius
Aug 14, 2005 08:07 AM
