xenocron chipped ecu has arrived, need some guidance
Old Oct 12, 2007 | 12:29 PM
tombakers's Avatar
Default xenocron chipped ecu has arrived, need some guidance
hi, my ecu turned up today andi was expecting there to be a plug in point for a pc lead but there isnt?, also there is a spare chip, one of them should have a a base map loaded on with crome compatible software, how would i know (by running the car)?? how do they plug there laptop in then if there is no plug?
Thanks,
Old Oct 12, 2007 | 04:21 PM
mxs's Avatar
mxs
Default RE: xenocron chipped ecu has arrived, need some guidance
if you need a datalogging cable, you need to specifically order it. Are you doing your own tuning? if you're getting someone else to tune it, they'll probably bring their own equipment anyway
Old Oct 13, 2007 | 02:12 AM
tombakers's Avatar
im not doing my own tuning im getting a company called thor racing to carry out this process, i will give them a bell and ask them. thanks
Old Oct 13, 2007 | 04:41 AM
tombakers's Avatar
Hi again,How do they program the ecu though, if there is no pc plug? do they remove the chip and plug something into the zif socket.
Thanks
Old Oct 14, 2007 | 05:55 AM
Typically, they will use their own ECU to do all the tuning. Then, once completely, burn the final maps to the chip, plug it into your ECU, and send you on your way.
Old Oct 14, 2007 | 09:17 AM
tombakers's Avatar
thanks again forty 04, very helpful
chooseross
Sep 12, 2009 09:10 PM
kuruma
Oct 25, 2007 02:22 AM
uk civhead
Apr 27, 2007 10:45 PM
rice_patrol
Sep 28, 2006 07:47 AM
sneekapeek
Jun 14, 2004 11:36 PM
