Viper 5000 Alarm
Old May 10, 2005 | 11:25 AM
Mikedg186's Avatar
Default Viper 5000 Alarm
Just bought a viper 5000 and i want to install it myself so does anyone know a site or something to show me step by step how to install an alarm?
i drive a 1995 honda civic CX HB
Old May 10, 2005 | 09:54 PM
LEVIII's Avatar
Default RE: Viper 5000 Alarm
Constant is a large white wire runing from the steering comumn to the fuse box.
Ignition is a large black/yellow running just below the constant.
Starter is white/black running with the constant.
Parking lights are red/black coming out of the top of the fuse box.
There is also a male blade in the fuse box that is p lights, I belive it is 3rd from the right but its been a long time since ive used that.
Door trigger is a large (mostly insulation) light green/red low in the driver kick, if you have cruise you may have to unbolt the bottom 10mm and move the silver box a little out of the way to acces it.
ground it to the kick after you scrape the paint away.
WOW, Ive done to many Hondas.
Old May 11, 2005 | 02:15 AM
Mikedg186's Avatar
thx lol
im sure theres more question i have when i start this :S
Old May 11, 2005 | 10:36 AM
LEVIII's Avatar
lemme know.
Old May 14, 2005 | 08:37 PM
Mikedg186's Avatar
i dont think i found the right wire for the door trigger, everything else works except the door trigger and the parking lights, couldnt find the parking lights wire
pls help
Old May 14, 2005 | 09:10 PM
LEVIII's Avatar
Do you have cruise control?
Old May 15, 2005 | 03:36 AM
Mikedg186's Avatar
nope, i have nothing power, no power windows, locks etc....
Old May 15, 2005 | 10:08 AM
LEVIII's Avatar
there should be a grey plug attached to the kick panel behind the carpet almost as far into the corner of the kick as you can go. The wire is in there. It is light green with a red stripe but is mostly insulation.
Old May 15, 2005 | 12:09 PM
Mikedg186's Avatar
and the parking lights wire is a small red with black stripe(i think) from the fuse box, but there are 2 red with black stripe
does it matter which one?
Old May 15, 2005 | 01:13 PM
LEVIII's Avatar
yeah there is prob more than one of that color. Do you have a test light?
