b16a2 w/ b18c1 head
Old May 12, 2005 | 08:33 AM
civic96RB's Avatar
Default b16a2 w/ b18c1 head
hey guys ive heard of a b18 with a b16 head...what exactly does this do??....and whats the diffrence if i get a b16 w/a b18 head? the b16 is cheaper and i just wanted to know if it gets any extra power w/ a b18 head.. thanks
Old May 12, 2005 | 10:09 AM
LEVIII's Avatar
Default RE: b16a2 w/ b18c1 head
B16 w/b18 head raises compression and yes you will get more power. B18 w/ B16 head lowers compression (good for boost) and the B16 head flows a little better. This is also known as the poor mans type R because the B16 head and the B18C5 head are very similar and even cast from the same mold.
Old May 12, 2005 | 02:03 PM
civic96RB's Avatar
so b16 w/ b18 head isnt good for boost? cause the compression ratio will be to high? or its fine but i wont be able to run that much boost?
Old May 12, 2005 | 03:56 PM
hondabboy's Avatar
the whole deal of high boosting is getting as much low compression as possible so you dont blow your motor.
high compression=low boost no more then about 8-12 psi depends on the motor
low compression=high boost i know a kid with a b20 block that has been work on and he can run 60 psi all day (i'll to get pics of the motor for you guys)
now thats what i know so far about the whole ideal of boosting because im boosting my b18b1 (which is a ls motor) reason why because it already has low compression about 9:2 or something
anyways if i do ls-v-tec i get more compression cause of the b16 head and i dont want that.
Old May 12, 2005 | 05:04 PM
civic96RB's Avatar
60 psi?! damn thats crazy...yea i figured high compression ratio was bad for boosting...theres a kid here that just bought a integra type-r boosted and he only run 13's...hes only pushin like 4psi
Old May 12, 2005 | 09:23 PM
LEVIII's Avatar
scarry to boost a stock type R. That is like the opposite of what they wer built for.
Old May 13, 2005 | 01:40 AM
esp on crappy Cali 91 octane[:@]
Old May 13, 2005 | 12:39 PM
Kappa22's Avatar
I feel your pain...
Old May 13, 2005 | 09:16 PM
LEVIII's Avatar
ORIGINAL: sacicons
Correction
**** water
Old May 13, 2005 | 10:37 PM
hondabboy's Avatar
lol cant wait to get mine done right now i have to get the kit for the turbo and im going to save up for the internal mods later on i plan on going about 12 psi(highest boost i'll go) for now on the stock ls and then when i get the money for the internals so i boost to 30 psi. just hope everything goes well.....
