have question about installing subs
Old Oct 30, 2007 | 06:46 AM
zuviex00's Avatar
Default have question about installing subs
so me and my 2 brother in laws installed subs in my car sunday but no power is going to the subs. we cant ground it anywhere can anybody help me. i dont know much about it and they had to go back to allentown (hr and a half away) i dont know when theyll be down next and none of us can firgure it out
Old Oct 30, 2007 | 07:43 AM
ShadFX's Avatar
Default RE: have question about installing subs
What is it your exacly asking? how to wire in a ground wire for the amplifier?
Old Oct 30, 2007 | 08:32 AM
zuviex00's Avatar
they guy who installed them said everythings hooked up correctly. we tried grounding it in several places but no power goes to the subs...might the wires be bad? what could be causing no power to go to the subs?
Old Oct 30, 2007 | 08:33 AM
mill$civic's Avatar
You cant ground it? In your trunk just look for a bolt to run the ground from your amp to, make sure you get some of the paint under the bolt scraped off for a good connection.
Old Oct 30, 2007 | 08:37 AM
zuviex00's Avatar
he tried it on a couple bolts but ill check to see if theres any paint that needs to be scraped off thanks
Old Oct 30, 2007 | 08:41 AM
ShadFX's Avatar
Dude, please try and explain better. Is there power to the amplifier driving the sub woofers? Or are you saying there is power to the amp, but no noise is coming out the subs?
Old Oct 30, 2007 | 09:15 AM
Luke_Jones's Avatar
Is there a fuse in the fuse holder that SHOULD be up by the battery? If so did the remote turn on wire get hooked up to the deck properly so the amp comes on when the deck is on? Definately need more clarity to the situation.
Old Oct 30, 2007 | 09:32 AM
sand off a piece of steel so that its completely bare steel, then use a self-tapping screw with a washer and screw the wire right down to it
Old Nov 26, 2007 | 07:49 PM
NYHondaCivic's Avatar
try checkin the fuse on the amp and the fuse that is on the battery(if you have one)...if not try to connect it in sumone elsesz car and see if the amplifier turnsz on and if it doesnt then that means there is sumthin wrong with the amplifier.
Slv09Honda
Apr 25, 2010 04:57 PM
destwinsburg
Apr 24, 2008 01:33 PM
dave_57204
Apr 6, 2008 05:38 PM
nwgt07
Nov 21, 2006 02:25 PM
Street Sniper
Jul 14, 2005 10:16 PM
