2000 Civic Rear Oil Pan Seal
Old Oct 30, 2007 | 01:42 PM
johndugan2's Avatar
Default 2000 Civic Rear Oil Pan Seal
guy at the dealership tells me he needs to replace the rear oil pan seal and that he has to drop the transmission to get to it. Costing about $1000 to fix and for labor. Is this necessary? He says its going to keep leaking oil till I get it fixed. Any of this sound familiar?
Old Oct 30, 2007 | 02:09 PM
AOL.COM's Avatar
Default RE: 2000 Civic Rear Oil Pan Seal
to change the oil pan gasket, you dont need to drop the trans , maybe he was talking about the rear main crank seal ?,for that you need to take the trans out , but $ 1000 is a bit much ,unless he's going to put a clutch kit in too
Old Oct 30, 2007 | 05:47 PM
mxs's Avatar
mxs
If he has to drop the trans, that's the rear MAIN seal. There is no "rear oil pan seal." It is a lot of labor but it is all fairly straightforward; if you have good tools, a good place to work, and a lot of time, you could probably do it yourself.
Old Oct 31, 2007 | 06:19 AM
Yes the transmission has to come out, which is not such a big deal actually. I agree $1000 is a lot. If it's manual you should be getting a new clutch for that price too. There is no extra labor to replace the clutch at the same time.
You balance that against what it costs to just let it leak and keep buying oil.
simons81
Apr 15, 2014 03:16 PM
Seth
Jan 27, 2012 12:40 PM
oilltd
Jun 10, 2008 04:06 PM
johndugan2
Oct 30, 2007 05:42 PM
cmansmith19
May 26, 2007 05:07 PM
