oil pan seal
1.) jack up car
2.) drain oil
3.) depending on clearance you will have to loosen or remove lower header pipe
4.) if it is an automatic skip this step, if its a manual, remove the plate between the tranny and engine, it covers part of the oil pan / bolts
5.) unbolt oil pan, make ure u have a big container under it or lots o news papers
6.) remove old seal, u may need to wire brush/ peel away parts.
2.) drain oil
simons81
Apr 15, 2014 03:16 PM
Seth
Jan 27, 2012 12:40 PM
oilltd
Jun 10, 2008 04:06 PM
