idle is loud & goes up & down--a problem??
Old Nov 8, 2007 | 12:17 PM
Lambo Civic's Avatar
Default idle is loud & goes up & down--a problem??
When I get home from work or get to work after about a 30-minute drive on the highway, I'll pull into my spot, and if I just sit there for a minute, the tach needle will rev up and down, and a lot higher than it used to. It's pretty loud and the needle doesn't just move a little--it really goes UP and DOWN. I'm totally guessing here, but maybe like 150-200 RPM from low to high and down again. Is something not right here? If so, what might it be? Thanks.
Old Nov 9, 2007 | 04:36 AM
Default RE: idle is loud & goes up & down--a problem??
Search: Idle Surge Issues
Its a thread I started when I was going through the same thing. Tons of troubleshooting info there.
Good luck!
Old Nov 10, 2007 | 05:11 PM
SovXietday's Avatar
Idle Air Control Valve (IACV).
Unbolt it, clean the screen, and enjoy your nice idle.
Old Mar 31, 2008 | 02:06 AM
soloxcivic's Avatar
https://www.hondacivicforum.com/m_56.../tm.htm#569518
thats not my case i have done that i found out its my FIV its cloged and its stuck open when i plug the lower port it stops im going to clean it when it gets light out and then let everyone know if that fixed it
Old Apr 2, 2008 | 03:09 PM
saLvic's Avatar
i have the same problem...also heard it is the throttle posistion sensor....i will try cleanin the idle crontrol valve, id love to enjoy a smooth idle....
Old Apr 2, 2008 | 05:17 PM
94DXProject's Avatar
My idle was doing the same thing a few days ago. Shortly after, I had disconnected the battery to change the fuel filter. Ever since then, the idle surge has been gone. I guess resetting the ECU (if that's what happened) did the trick. Not saying that's your problem. Just saying... lol
Good luck, man.
Delray_Pete
Dec 3, 2011 01:23 PM
SPACEGUY18
Nov 20, 2009 02:01 PM
islandtuner
May 4, 2009 08:54 AM
TrAvMaNFTW
Feb 19, 2006 12:19 PM
