code po108 need help!
Old Nov 27, 2007 | 11:44 AM
rcalimquim's Avatar
Default code po108 need help!
first of all my car is a 97' civic ex 5-speed. im getting the engine code po108 (map/baro circuit high input) need some help.
Old Nov 27, 2007 | 01:57 PM
Default RE: code po108 need help!
The problem could be the MAP sensor itself, or also possibly wires serving the sensor or the ECU.
If you have access to a scan tool (e.g., Actron) that reads Manifold Absolute Pressure (MAP), then you could perform the test described in the picture and determine whether your MAP sensor is bad.
If you wish, I would be happy to post the remaining P0108 troubleshooting procedure, which also includes tests of MAP sensor wires and the ECU.
[IMG]local://upfiles/25538/9D842BF4331E4A5DB6B516A809119D84.jpg[/IMG]
jdtrio
Mar 17, 2010 02:52 AM
ioang26
Dec 31, 2007 08:34 AM
ioang26
Dec 30, 2007 03:33 PM
ktownjeep
Jun 20, 2007 01:40 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
