questions about 550cc injectors
Old Jan 9, 2008 | 04:29 PM
didder's Avatar
Default questions about 550cc injectors
im installing rc 550's in my soon to be insanely boosted civic and i have a few questions just to throw out there to get some numbers of what my goals can be
im going to be running the rc's as stated and pump gas... (92 octane)
will i be able to reach 350whp? petes sticky says yes, but i dont know how accurate it is..
has anyone ever maxed out 550cc injectors? or know someone that has? im just getting pumped cuz this install is going down real soon.
thx guys
-didder
Old Jan 16, 2008 | 11:49 AM
MY99SI's Avatar
Default RE: questions about 550cc injectors
550's wouldnt be hard to max out. it all depends on alot of things. every car isnt the same, every setup is different. so its hard to say XXX amount of power you will make, or expect to make
Old Jan 16, 2008 | 12:02 PM
http://www.witchhunter.com/injectorcalc1.php4
fuel injector calculator...it says like 540 cc would be perfect, at like 80% duty cycle, idk, put in your info and see what happens.
EDIT: this one was good too: http://www.iroczone.com/calcs/injectorsize.htm
also PM Mobsta, he posted up a good one not too long ago for somebody
Old Jan 16, 2008 | 12:07 PM
MY99SI's Avatar
i personally would get a larger injector than a 550, that way you have extra fuel there if you need it and dont have to worry about spending the extra money for larger injectors later. get the bigger ones to start with then pull fuel out of the fuel table as needed.
Old Jan 16, 2008 | 04:08 PM
LarsonSi_0091's Avatar
i have 525cc injectors in my car and its supposed to be able to handle about 85 hp per cylinder which is about 340 hpso you should be alright
gcsd3742
12
Jul 21, 2008 05:39 AM
didder
Feb 4, 2008 12:33 PM
oldguy
Mar 17, 2007 01:03 PM
xxk1llaxx
Oct 24, 2006 01:29 PM
spoolin12
Jun 10, 2005 11:03 AM
