550cc's on a 440cc basemap (help!)
Old Jan 28, 2008 | 01:37 PM
didder's Avatar
Default 550cc's on a 440cc basemap (help!)
tried my motor swap, everything went wrong so now im running my stock d16 on a 440cc turbo basemap with 550cc injectors and a walbro fuel pump.
finishing the swap asap, need to get my venom intake mani machined and the right arp headstuds. (dont ever do a swap without doing a complete inspection on the motor first I learned the hard way)
question is, am i running lean as all hell? because my car is mad crazy powerful right now and its scaring me [&:]
Old Jan 29, 2008 | 10:34 AM
MY99SI's Avatar
Default RE: 550cc's on a 440cc basemap (help!)
you should have a wideband to answer that question for yourself
Old Jan 29, 2008 | 03:09 PM
didder's Avatar
have an aem uego, but havent installed it because i was to frustrated lol, guess i will sometime this week
Old Jan 30, 2008 | 09:23 AM
MY99SI's Avatar
its EXXXXXXXXXXTTTTTTTTREAMLY easy.. you put the sensor into a bung in the exhaust, and u hook up a switchable power and a commen ground and your done
its very simple.. shouldnt take more than 30 min if you get sidetracked for 20min
Old Jan 30, 2008 | 10:43 AM
didder's Avatar
yea, wher should i run the cable through? or would it be easiest to drill a new one, throw a grommet on and runit through that?
Old Feb 2, 2008 | 07:07 PM
cpl rampage's Avatar
if anything it would be rinning rick because it is injecting more fuel then it thinks it is, but you shouldnt be dring anyfaster than needed cause its not tuned.
Old Feb 2, 2008 | 10:29 PM
didder's Avatar
installed the wideband and its running pretty damn good
at idle: 11.2-11.5 a/f
cruise: 13.7-14.3 a/f
at 4/5 throttle: 15-16 a/f (a little high but i dont know why)
at full throttle: 11.1 (ecu tuned for tubo [:'(])
if those numbers seem a little off someone let me know lol
Old Feb 4, 2008 | 12:33 PM
riceburner700's Avatar
looks a little lean during 4/5 throttle and looks a smidge rich at WOT, 11.5-12.5 is good for WOT
didder
Jan 16, 2008 04:08 PM
tombakers
Nov 28, 2007 10:41 PM
xxk1llaxx
Oct 24, 2006 01:29 PM
JDM_HONDA_LOVE
Aug 15, 2006 11:48 AM
spoolin12
Jun 10, 2005 11:03 AM
