2 inch drop on springs and stock shocks
Old Feb 21, 2008 | 01:58 PM
raz's Avatar
raz
Default 2 inch drop on springs and stock shocks
I have searched and never got a real clear answer. If I just do a 2 inch drop all around just srpings on stock shocks will I need to get new shocks? if so I got some in mind. also do i need to purchase all 4 shocks or just 2...every place i se sells them for about 80 each and im trying to stay within my 300 budget.
I jusy want something for a DD and still have some good performance aspects.
Thanks
Old Feb 21, 2008 | 02:06 PM
nebrown1's Avatar
Default RE: 2 inch drop on springs and stock shocks
you should do all 4 shocks or your stock ones mit blow out. you sure you want to do a 2 inch drop i just did a 1.8 in the front and 1.5 in the back. and my car hit's the ground
Old Feb 21, 2008 | 02:08 PM
raz's Avatar
raz
ok cool. really!? wow and thats my concern. I have a body kit and really dont wann mess it up.. but 2 inches would fill the gap better...how big is your gap?
Old Feb 21, 2008 | 02:13 PM
civicexracer's Avatar
yeah u'll want to replace the shocks. easier and cheaper to just do it all at once. u'll need all 4.
Old Feb 21, 2008 | 02:15 PM
raz's Avatar
raz
Ok for 7thgens I heard ground control is good spring..
I have an offer for 100$ springs..dropzone..are they ok? and whats a good shock to get thats not freakin 80a piece..keep in mind my 300-350 limit please
Old Feb 21, 2008 | 02:39 PM
Ground Control makes coilovers and they use Eibach springs on them. their also quite a bit more expensive then ur run of the mill springs. dropzone's are junk, for an extra ~$100 u can get Tein S-Techs brand new. probably the cheapest decent shocks u'll find would be the Tokico blues or the KYB GR2's. parts are more expensive for ur generation so u may want to up ur budget a bit.
Old Feb 21, 2008 | 02:47 PM
raz's Avatar
raz
so what would you say would be a great DD setup..around ok lets say tops 600..perferable less tho
Old Feb 22, 2008 | 10:34 AM
raz's Avatar
raz
bump
Old Feb 22, 2008 | 05:27 PM
SITNLOW97's Avatar
If u have a kit on and its urr dd i would go with tein s tech's and tokico struts....thats gonna run u prolly about 500 on ebay just make sure there the real ones and not fake...but keep in mind u will need a camber kit if u dont already have one...
Old Feb 22, 2008 | 05:28 PM
SITNLOW97's Avatar
But if ur on a really tight budget u could get by with just springs on stock struts only if u getn tein springs...
