JRSC Problems
Old Mar 15, 2008 | 08:31 AM
phil0975's Avatar
Default JRSC Problems
I finally got the JRSC installed and running right on my 1991 Civic SI until the other day. When driving home from work I noticed I could not hear the charger at low RPMS. When I get in the upper range I can hear the charger however it doesn't have the pull that it use to. The car runs as if the charger is not there. I called Moss Motors who suggested that I may have a vaccum leak. I sprayed WD40 near the intake and no change in idle. All the hoses are new so I don't think they are to blame. Anyone have any ideas? I'm really concerned that I can't hear the whine of the charger anymore... Any help/advice would be much appreciated.
Old Mar 16, 2008 | 10:41 AM
Mr Mobsta Man's Avatar
Default RE: JRSC Problems
Do you have a boost gauge? What are you using for engine management? Are the belts tight?
Old Mar 16, 2008 | 03:32 PM
SovXietday's Avatar
Sounds like you have loose belts.
Old Mar 16, 2008 | 05:39 PM
phil0975's Avatar
No boost gauage but the belts seem tight. I have a gauage but have not had the opprotinuity to install it. The car is stock aside from header, MSD, Flowmaster cat back, KN&N Air filter and RC injectors. I have a Welboro fuel pump but haven't installed that either. No engine management.
Old Mar 18, 2008 | 06:35 PM
SovXietday's Avatar
The sound comes from the two rotors spinning, so you're looking at slipping belts or something along those lines being messed up.
finalimpact
13
Sep 23, 2006 10:43 PM
Forty04
Jul 11, 2006 08:50 AM
Street Sniper
Mar 24, 2006 01:11 AM
smelldaodaa
Nov 20, 2005 01:50 PM
Street Sniper
Jul 30, 2005 09:38 AM
