NEED HELP
Old Mar 19, 2008 | 11:33 AM
ballincivic94's Avatar
Default NEED HELP
Im trying to turbo my honda civic (d16z6)but i dont know wether to buy a kit or build one around a Garret turbo. Also does the GReddy turbo kit allow you to keep your a/c. If you can tell mea good size turbo to keep stock internals and run at 7psi along witha manifold that allows me to keep my a/c please help me.
Old Mar 19, 2008 | 03:14 PM
Mr Mobsta Man's Avatar
Default RE: NEED HELP
The search button doesn't bite, I promise.
Gah, okay. I'm in a good mood so I will tell youanyway even though this has been discussedliterally hundreds of times. Building is cheaper but requires some knowledge. (this would require you to search more btw) Greddy kits allow you to keep a/c. Don't base your goals on a psi, go for a power level. 7psi on a small turbo will not make nearly as much hp as 7psi on a bigger turbocharger. t25 turbo would be a good choice for a stock internal setup. Log manifolds are a good way to go to keep a/c and are good up to 300hp.
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
