Weird Transmission noise
Old Mar 29, 2008 | 03:53 AM
jericho07's Avatar
Default Weird Transmission noise
I have a '96 Civic LX with a 5 speed transmission. It drives great, but I have noticed a weird noise that seems to be coming from the transmission.
If I am driving and slow down in first or second gear (say, to pull into a parking space), I notice a slow, methodicclicking or ticking noise like a baseball card in spokes of a bicycle. It only does it with the clutch pedal out and only when I'm not accellerating. If I push the clutch pedal in it stops. The noise also happens at slow speeds briefly just as I'm releasing the clutch after shifting gears.
If I sit with the car idling in neutral with the clutch pedal out. It sounds a little noisier than normal as well.
At normal driving speed or if I'm accellerating there is no noise at all.
During the past year, I have had the clutch, pressure plate, thow-out bearing and both axles and all cv joints replaced.
My guess is the input shaft bearing. If it is the input shaft bearing, should I be afraid to drive the car, and do I need to get it replaced right away ?
Old Mar 29, 2008 | 05:35 PM
jericho07's Avatar
Default RE: Weird Transmission noise
Today I noticed that is sounds more like a growling noise than a clicking. It does it in first, second, and third gears. It's looking more and more like an input shaft bearing. How long can I drive it like this without replacing it? It's a '96 and I really don't want to put a ton of money into it.
Old Aug 5, 2008 | 04:18 PM
djcompton's Avatar
Sounds like Input Shaft bearing to me....look at the sticky about it. I just changed mine...it's not too bad to do really.
jonsaidthat
Jul 20, 2011 01:34 PM
clownbaby
Aug 31, 2009 02:06 PM
marcin69k
May 25, 2007 04:25 PM
95lx
Aug 20, 2004 04:51 PM
bills99si
Jul 2, 2004 04:43 PM
