Installing Fog Lights HELP!
Old Apr 9, 2008 | 01:14 PM
Bostonhoodhop's Avatar
Default Installing Fog Lights HELP!
Ok ive been doing this for a few hours now have the bumper off and the holes drilled and done i am following the DIY but im stuck at where you locate the wire taped with blue to your car i dont see what i connect it to.. anyone done this before?
Old Apr 9, 2008 | 01:15 PM
Default RE: Installing Fog Lights HELP!
btw this is on a 99 coupe
Old Apr 9, 2008 | 01:40 PM
T3rry's Avatar
Member
what DIY are you following?
Old Apr 9, 2008 | 02:44 PM
Civic Si 00's Avatar
The connector is by the Water reservoir bottle, below it(windshield fluid) I just did my 00 Si and the connections are the same for your model.
Here I got this info Thanks to Addiction
This located below the water reservoir tank for the windshield fluid and below the power steering bottle
thats the wire under the dash to connect to....
then the next is under the dash....
THAT SHOULD DO YA.... at least for OEM fog light instalation....
the other light harness is easy... just take the under-steering wheel cover off and unplug the headlight harness... plug in the OEM harness that goes between that conection... and run the relay over and use the longer bolt to secure the included relay....
https://www.hondacivicforum.com/m_37.../tm.htm#378377
Old Apr 9, 2008 | 03:17 PM
o ya beat me to it
ya hardest part with the foglights is finding those 2 wires! which was why i took pictures of them.
Old Apr 9, 2008 | 07:29 PM
cyberx32's Avatar
Stupid small wires lol it took me forever to find them too.
Old Apr 15, 2008 | 01:04 PM
ok now. next question could it be that my fog lights dont use the brown plug under the winshield washer fluid because i found it and i have nothing that plugs into that. i nonw only have one remaining plug which im assuming goes into the brown plug behind the fuse box inside.. everything under the hood is hooked up.. now what needs to come inside the car.. the switch the relay, the ground and the brown plug that goes into the plug behind the fuse box.. i havent found that plug yet bbut my remaining plug from the harness is the same plug as the plug on the wire under the washer fluid... HELP lol
Old Apr 15, 2008 | 04:14 PM
what now..... please be clearer...
if your foglight wire harness will not plug into that harness in the engine bay then you dont have OEM foglights!!!!!!
the oem foglights has that one conection up in the engine bay, and the same style inside the car behind the fuse box, and one larger harness between the headlight switch harness. then it was just the switch conection and the relay conection...
those pictures above are the ones i used with my instal in my 99. i took 2 pictures of the under the dash harness conection.
tho you can custom wire up your own foglights and fit them any how you want its just alot messier!
Old Apr 30, 2008 | 03:49 PM
civicSIfnatic's Avatar
Ok so I know this thread is slightly old, but I need some help and I have a couple of questions.
I have a 2000 Si and I'm installing JDM OEM fog lights. I read through this and I dont think I have a plug that goes between the headlightplug and the headlightplug slot. Im not sure if the switch harness for the JDM fogs is different from the USDM and whether or not the JDM switch harness has the plug that goes between the headlight plug and the headlight slot.
If someone could help me out, I would appreciate it. Thanks in advance.
DjHagios
Aug 13, 2010 10:21 PM
WellFedHobo
Sep 12, 2008 11:01 AM
JenniferLa
Dec 6, 2007 02:24 PM
aznxboi19
Jan 12, 2006 08:22 PM
voz
29
May 19, 2005 09:30 PM
