compression test
Old Apr 27, 2008 | 02:44 PM
kevlws23's Avatar
Default compression test
I have a 96 Honda civic lx I gave it a compression test and it came to 90-97 and I was just wondering Ware it should be. i was thinking about adding n2o
Old Apr 27, 2008 | 04:14 PM
Mr Mobsta Man's Avatar
Default RE: compreshion test
You spell like a 3 year old.
Are you sure you did the test right? Because if your compression is in the 90's your engine is ****ed.
Old Apr 27, 2008 | 05:50 PM
kevlws23's Avatar
Default RE: compression test
sorry about the spelling i am 14 i think i did it right i pulled the plugs inserted the compression tester and turned it over until i got the highest # can you tell me what it should test out to or maybe a link thanks
Old Apr 27, 2008 | 06:58 PM
You have to push the pedal down to the floor when you do it, also take out the ecu fuse so the dizzy isn't trying to make a spark while you are cranking. The numbers should be around 190-200 and within 10% of each other. If you are 14 years old there is no way you are going to be able handle a car with nitrous. Do you know what torque steer is?
Old Apr 27, 2008 | 07:46 PM
boostedct9a's Avatar
wow, I don't think that your doing it right, check with a tech on how to do it on your car, sometimes it varies like on mine. Oh and don't add nitrous oxide to a stock block and head unless you feel like pulling your motor out a month later and replacing pistons you blew a hole through.
Example:
http://i41.photobucket.com/albums/e2...PistonHole.jpg
Old Apr 28, 2008 | 04:57 AM
*Sighs*... You can run nitrous on a stock engine if you do it right.
Skrapdoggydog
Jan 16, 2007 01:14 PM
b8teen
17
Dec 19, 2006 06:17 PM
01CivicEX
Aug 30, 2006 11:05 AM
Meta
Aug 10, 2006 01:46 AM
chones2083
Jun 2, 2005 06:48 PM
