new rims/tires q
Old May 7, 2008 | 01:19 AM
lcn584's Avatar
Default new rims/tires q
thinking of changing my stock 13-inch rims (with 175/70R13 tires) into 15s with 195/60R15 tires. would this be ok on a 93 civic? will it fit my wheel wells and will it not affect my steering? i mean since they are bigger, there might be less space to move inside the well for steering?
Old May 7, 2008 | 07:14 AM
KarTuneMan's Avatar
Default RE: new rims/tires q
Wheel offset is the key. Don't get a 15x7 with a +35mm offset. A 6.5 with as close to a +45 would be ideal.
Old May 7, 2008 | 12:12 PM
civicexracer's Avatar
ORIGINAL: KarTuneMan
i have 15x6.5 with +35mm on 195/50R15 and no problems whatso ever, sitting pretty low with no camber adjustments either. 15's with that tire size should be fine. try to get the lightest wheel possible, weight will probably be the biggest factor u'll feel.
Old May 8, 2008 | 04:29 PM
stoochy's Avatar
Not sureif you want to go 16's, butI have a 95with 16x7's with a +40 offset, 205/45/16 tire. Its lowered and doesnt rub at all.
safety4th
Oct 27, 2010 12:27 PM
remy
Aug 15, 2008 08:13 AM
kikaSI
Nov 13, 2006 11:52 PM
cornerblitz59
Jul 24, 2006 10:51 PM
bloohatch
Jul 23, 2005 10:05 PM
