broken lug stud
Old May 19, 2008 | 07:04 PM
javon's Avatar
Default broken lug stud
[/align]ok today i was taking my rims off, amd some of my lock lugs broke the bolts off. on one spindle it broke two bolts is there any way i can replace theses bolts with out getting a new spindle. there are only 2 lugs holding the front 2 wheels on does anybody know how to fix the front [/align]
Old May 19, 2008 | 07:27 PM
mill$civic's Avatar
Default RE: broken lug stud
We have a DIY on replacing broken studs in the DIY section, check it out. I did my back ones before, it was really easy, I just poped the old one out and put the new one in.
Old May 19, 2008 | 07:53 PM
javon's Avatar
do i do the fronts the same way
Old May 20, 2008 | 05:49 AM
pretty much... and the studs are like $1 at autozone/advance auto
Old May 20, 2008 | 01:35 PM
the DIY has alittle more harder for the fronts but the rears are really easy!
if you got alittle grinder and follow the DIY you can do well...... either way if you drive the car keep it slow till it gets fixed!
Old May 20, 2008 | 06:00 PM
SilverSedan's Avatar
um...if possible don't drive it at all...you only have 2 lugs holding your damn wheels on! Swapping studs isn't a big deal though. The last stud replacement I did was on a semi....take of the wheels, the hub (which is oil filled, with 2 roller bearings) then beat the tar outta them to get them out.. Honda's are pretty easy in comparason
Old May 20, 2008 | 06:18 PM
ncc admin's Avatar
if they are on the front honestly that is worse than on the rear. the worst part is taking the hub off for that the easiest way is to use a hub puller which you can get from like auto zone or kragen with their loaner tool program. then ya just pound the old ones out and put the new ones in. if you really don't feel comfortable doing it then take it to a tire shop and they should be able to do it no problem and they shouldn't charge TOO much to do it
burnindesirez02
Sep 9, 2020 08:26 PM
CivvyCloud
Nov 18, 2008 05:36 AM
herbaleyes
Oct 5, 2007 01:34 PM
nutty_360
Feb 15, 2007 10:59 AM
Jippo99
Mar 22, 2005 07:00 PM
