Using old head gasket/broken stud
Old Oct 5, 2007 | 11:24 AM
herbaleyes's Avatar
Default Using old head gasket/broken stud
Quick question:
What will happen if I remove the head of my d16, fix it, and put it back on using the same head gasket? What are the risks? How serious of a no-no is this?
I've got a stud from the exhaust manifold that broke off slightly inside the head itself. I'm considering trying to drill/spin it out, MIGing it and trying to turn that sob, or just takin the head off and removing it. Any suggestions?
This header is getting outta control. So far, I've replaced the o2, dealing with broken stud, and i get an occasisonal CEL. This is fun.
Old Oct 5, 2007 | 11:40 AM
riceburner700's Avatar
Default RE: Using old head gasket/broken stud
you risk filling your cylinders with coolent and bending valves, you can also trash your motor because the coolent will seap into the crankcase and isnt very good at lubricating mixed with oil so there goes your bottom end
Old Oct 5, 2007 | 12:05 PM
ya for the cost... replace it as well as other seals while the motors apart. save yourself a NASTY driping oil spot leaving its mark everywhere ya go!
just dont cheap out or else youll REALY REGRET IT! and after ya put the head back on spin the motor over by HAND OR SOCKET and if it binds on anything they you dont have the cam shaft lined up right with the crankshaft... alot beter than trying the starter and bending a valve!
Old Oct 5, 2007 | 01:34 PM
herbaleyes's Avatar
You don't know how much I appreciate these fast replies. Thanks guys.
ORIGINAL: addiction2bass
Exactly why I didn't want to change hg's. Cause then I might as well just do all of em.
slade8
Dec 6, 2009 06:23 PM
javon
May 20, 2008 06:18 PM
Carlz0r
Dec 15, 2006 12:26 AM
red2000Si
Oct 12, 2006 08:05 PM
Jippo99
Mar 22, 2005 07:00 PM
