What should it run? And how much boost
Old May 27, 2008 | 10:36 PM
Max713's Avatar
Default What should it run? And how much boost
what do you guys think this car should run in the 1/4?
also, its tuned for 12psi and its running on 8psi right now, can i run 12psi as a DD safely?
94 Civic EX
d16z6 swap
t3 t4 Turbo, intercooled,running 8lbs, or 12lbs
HKS blowoff valve
Mugen 2.5" full exhaust
New 3 stage clutch with 8ld flywheel
550cc injectors
Walbro 255 fuel pump
Tuned on chrome
Independent fuel injection
right now its on steelies, soon to be 17s...
Old May 27, 2008 | 11:26 PM
arust45's Avatar
Default RE: What should it run? And how much boost
12lbs on that size turbo seems kinda sketch on a stock motor, then again it depends on how good the tune is and how much power you're making at that boost. And for 1/4 mile time, all depends on the specifics of your setup. Traction, specs of turbo, driving experience, and tune can dynamically influence track times. Best way to find out is to take it for a few runs.
________
LipsLove cam
Littlehag
Jan 19, 2021 09:49 AM
samilitant
Jan 8, 2007 10:47 PM
tombakers
Nov 20, 2006 08:53 PM
Pete
Jan 16, 2006 12:18 AM
Remmy
Mar 6, 2005 01:18 PM
