99 ex auto to manual swap
Old Jun 4, 2008 | 12:51 PM
BAKnBLACK's Avatar
Default 99 ex auto to manual swap
this weekend ill be buying everything i need for a full swap and ive heard i have to completely take the engine out for it i wanted to know if this is true also if so wat maintence should i do on the negine while it is out of the car thnx for your suggestions
Old Jun 20, 2008 | 01:59 PM
Default RE: 99 ex auto to manual swap
new throwout bearing
if you got the money put in an aftermarket clutch disc, pressure plate, flywheel, short shifter
Old Jun 20, 2008 | 08:02 PM
SilverSedan's Avatar
+1
If you got everything pulled out, you might as well upgrade drivetrain stuff clutch and bearing, shifter, CV axles (if you're gonna go after big power) things like that... might want to consider swapping out your engine/trans mounts for stiffer ones too.
BillyB98
Sep 18, 2007 08:52 PM
Fiirkan
Feb 28, 2007 06:56 PM
meangreen
Sep 30, 2005 08:09 AM
MichiganRice22
EG Swaps
Sep 11, 2005 04:25 PM
the_reptilian
Jan 12, 2005 06:30 PM
