How difficult is it...
Old Jul 2, 2008 | 02:11 PM
Default How difficult is it...
...to replace the rocker arms on a Pontiac? Or even a Civic? Is it a hard thing to do in general?
Old Jul 2, 2008 | 04:27 PM
Default RE: How difficult is it...
No idea on the Pontiac (there are a lot of different kinds of Pontiacs out there) but it's quite simple on a Civic, at least a SOHC. Remove the valve cover, take out the bolts holding the rocker arm/cam bearing assembly down, lift the assembly out as a unit. Pull the assembly apart carefully noting where everything goes, and replace rocker arms. Installation is, of course, the reverse of removal.
I have to wonder why you need to. The rocker arms are adjustable to compensate for wear. That's unlike American designs that have "lifters" that adjust themselves.
Old Jul 2, 2008 | 04:33 PM
This would be on a newer Grand Am. A cute redheaded friend of mine had her engine start knocking and the shop said that the rocker arms were the problem. She can't really afford to get that fixed, so I was looking into how hard it would be to do that.
Old Jul 2, 2008 | 04:54 PM
Sure she's not talking about rod knocking, which occurs when the main or rod bearings are destroyed from running out of oil? This is a low-pitched clunking from the bottom part of the engine. Time for a new engine, or a new car, in that case.
If it's more of a clicking or tapping in the top part, I think those engines have lifters and one or more of the lifters could be stuck. The rocker arm itself is not a part that is replaced routinely.
Old Jul 2, 2008 | 05:27 PM
All I have to go by is what she said the mechanic said.
Old Jul 2, 2008 | 07:14 PM
Mr Mobsta Man's Avatar
Take a look at the engine yourself, also if you can get a video with the hood up and it running so we can hear it.
zachattack
Sep 14, 2007 07:33 PM
bluecivic91
Aug 1, 2007 12:19 AM
Firehawk989
ED-EF Swaps
Jul 21, 2006 08:47 PM
TENGRAM
Apr 18, 2006 01:13 PM
sir_nasty
Mar 21, 2006 04:47 PM
