CRX PUSH BUTTON?
Old Jul 12, 2008 | 08:40 AM
branx's Avatar
Member
Default CRX PUSH BUTTON?
HI THERE i have an 88 crx si and the ignition system is kinda of broken, like it will do everything but it wont start when i turn the key all the way, so if someone could show me just how to wire a buttton to engage the starter, also do i need a special button or can i use anyone?
Old Jul 12, 2008 | 10:20 AM
Default RE: CRX PUSH BUTTON?
search
Old Jul 12, 2008 | 11:06 AM
you could also take your vin number to any honda dealership and have them cut you a new key..... most likely your key is worn and also sticks in the locks as well. dont just get a copy cut at any cheap store the cut will be the same worn down to the nub! get a new key cut that will be cut just like it came brand new!
Old Jul 19, 2008 | 08:38 AM
05reverb's Avatar
the problem is not with the key, cause he is able to turn the key all the way, the trouble is the switching mechanism inside the ignition, or cut or loosestarter wire on the ignition harness. if everything works when you turn the key, and just not the starter, and you are sure the problem is in the ignition, I can tell you how to do a push button. I did it inmy 05 civic. I'll just tell you the simple way, so you will still need to turn your key to on, cause to do it without a key, is way harder for me to explain over the internet. All you need to do, is tap into the big white wire in the ignition switch (constant +), and the big Black/White wire in the ignition switch (starter wire), and hook it up with a relay and a push button. I drew a diagram, so if you want me to send it to you, send me your email addy.
Here is mine....
Old Jul 19, 2008 | 07:39 PM
import tuner's Avatar
It just sounds like you need a new starter
Old Jul 20, 2008 | 07:16 AM
315 Customs's Avatar
fdgdsgdf
Old Jul 20, 2008 | 12:06 PM
yea i agree with import tuner. you need to test your starter wire with a multimeter - its the black/white wire coming out of the ignition cylinder. If your multimeter reads 12 volts when u turn the key to crank position then its most likely your starter then
Imari007
May 30, 2007 07:02 PM
Imari007
May 23, 2007 01:50 PM
studfou83
Oct 21, 2006 12:27 PM
civic_vtec_SiR
Oct 16, 2006 01:51 AM
TrAvMaNFTW
Feb 22, 2006 01:17 PM
