95 civic TPS Sensor issue
Old Jul 22, 2008 | 06:47 AM
gas_miser's Avatar
Default 95 civic TPS Sensor issue
Can you replace a TPS sensor on a d16z6? I have a dead spot in my pedal and I am almost positive that the TPS is bad. The car has a ton of miles on it. I checked with honda and they said it is attached to the throttle body and you have to replace the entire assembly. Any help is greatly appreciated.
Old Jul 22, 2008 | 06:52 AM
gas_miser's Avatar
Default RE: 95 civic TPS Sensor issue
oh, the car is a 1995 civic ex with the d16z6 as well. I have replaced the timing belt, idler pulley, cam/crank seals, plugs, wires, air filter, fuel filter, fuel pump, sending unit, and all belts. I also checked the ignition timing. The car is getting 36 mpg, but it hits a dead spot about half pedal every time no matter how you accelerate. Its in the same spot. I can accelerate all the way to the upper rpms if i accelerate slowly. I just wanted to add this information in.
Old Jul 22, 2008 | 07:28 AM
No CEL though? You can test the sensor with a voltmeter to be sure it is bad.
Officially the sensor is not replaced seperately, but if you can find one it can be. Drill out the breakaway screws and put the new one on with regular screws. The sensor must be calibrated when replaced onto the throttle body.
Old Jul 22, 2008 | 07:49 AM
gas_miser's Avatar
no...there is no CEL light on and no codes have been set. I found a couple new ones on line. how do you calibrate the new one?
Old Jul 22, 2008 | 07:55 AM
gas_miser's Avatar
what should the voltage read on the sensor?
Old Jul 22, 2008 | 08:51 AM
About 0.5V with throttle fully closed and about 4.5V with WOT.
Are you sure the ignition timing is not off?
Old Jul 22, 2008 | 09:43 AM
gas_miser's Avatar
The car has had the same issue since i brought it home. We have replaced the timing belt and everything listed above. We have also checked the ignition timing several times. We even retarted and advanced the timing. It still has the exact same issue now as it did before. I do know that it acts up in the exact spot in the pedal every time.
Old Jul 22, 2008 | 10:09 AM
Measure voltage from the center wire to ground with the sensor connected, key on, but engine not running. The voltage should increase smoothly from 0.5 to 4.5 as you move the throttle slowly from closed to wide open.
To calibrate a new one, loosen the screws and rotate the sensor so you get 0.5 volts with the throttle closed.
Old Jul 22, 2008 | 10:18 AM
gas_miser's Avatar
thank you mk378. does anyone recommend a aftermarket one. I wasnt sure if one brand was better than the other.
Old Jul 22, 2008 | 09:48 PM
turkeysandwich's Avatar
I would highly recommend buying an oem sensor from http://www.inlinefour.com/il4oemretps.html . You can also find one at http://www.omnipowerusa.com/ but I bought one from there and it ended up going bad, it could have been something I did or just a bad sensor though.
